DP83822IF: Magunetic supply 22mA on Table 135. Power Supply Characteristics
Part Number: DP83822IF
Hi all
Would you mind if we ask DP83822IF?
Is Magunetic supply 22mA on the datasheet P93 Table 135. "Power Supply Characteristics" the current which indicates the total current at the datasheet P88 Figure 31. "TPI Network Circuit"?
And then, in case of full temparature 85C, does the current increase?
Kind regards,
Hirotaka Matsumoto
  • Hi Hirotaka-san,
    Yes, the Magnetic supply in the table refers to the current consumed by the external termination resistors and the center tap of the supply.
    The current measured is for nominal. Yes, this current will increase at temperature.
    Kind regards,
    Ross
