Part Number: TUSB551
Other Parts Discussed in Thread: TUSB55
Hi Chun,
The application works fine?
When you try to take eye-diagram captures are you setting Rx terminations?
Scope vendors provide adapters to set this terminations.
Hi. Moises Garcia
Hi Tyler,
The schematic looks fine, I would like to clarify some points.
J1 is a USB connector?
what do you mean with transmitting the image? what is the image?
If this device is connected to a Host( or Host connected to the device) does it work fine?
If you remove TUSB551 and bypass it, can you take the eye-diagram?
Does the scope have Rx terminations to do Rx testing?
Hello Tyler,
I would like to confirm that you have a fully functional port, please cheack that the attached device is connecting @ USB3 (perhaps the device is being enumerated as USB2). You can use the USB tree view software to confirm this connection.
Diego.
