Part Number: DP83867IR
I would like to avoid using a Hub or a Switch in a 10/100BASE-T ethernet bus. I propose to use TX_CNTRL from master to each one of the slaves. This control signal will enable PHY only of desired module, so, I will avoid any conflict of different modules accessing to the bus.
Is my approach correct ?
( I wanted to attach an slide showing the proposed architecture, but I couldn't attach it)
