TUSB9261: Power up sequence after considering ERRATA
Part Number: TUSB9261
Dear Specialists,
My customer would like to confirm the power up sequence of TUSB9261 after considering ERRATA.
Could you please see and advise following questions ?
---question---
According to the datasheet, recommended core power(VDD=1.1V) and I/O power(VDD33=3.3V) at the same time.
On the other hand, 1.1V power up time should be equal to or less than 3.3V power supply.
http://www.tij.co.jp/jp/lit/er/sllz065b/sllz065b.pdf
Is there any limitation of timing spec between core power(1.1V) and I/O power(3.3V) ?
Current situation, once the device has failed in recognition, it never restart by GRSTz.
I appreciate your great help in advance.
Shinichi
    [answer]: No, there is no specified time, as long as VDD is in the valid "high" limit before the VDD33 rail everything will work fine.
    You can share your schematics for review.
