Part Number: TPS25740A
Other Parts Discussed in Thread: TL431
Our customer Colt Advance has a question about the usage of TPS25740A USB TYPE-C PD DFP side with MacBookPro.
Customer already paired their TPS25740A USB TYPE-C power supply with MacBookPro to provide 14.8V for the charging, but customer found that when the MacBookPro 100% fully charge + shut down mode + close the cover then plug into their USB TYPE-C power supply, the MacBookPro will have a “Don” sound, it is normal, after a few second, their USB TYPE-C power supply will drop from 14.8V to 5V, after around 3 second their USB TYPE-C power supply shown the output voltage ramp to 14.8V again and MacBookPro has a “Don” sound again, this symptom will happen in a loop.
note: This symptom will not happen with the “original MacBookPro power supply”.
Could you please help to check what happen on it and how to solve this issue?
