Part Number: DS125DF1610
Hi TI expert
I am designing USB type C cable tester which may use retimer for design implementation. the purpose of retimer is used to generate PRBS and Check PRBS over the Type C cable. The E Marker type c cable will support up to 10Gbps data rate
From my understanding, as for Input Lock : 9.8 Gbps to 12.5 Gbps (plus divide-by-2, divide-by-4, or divide-by-8 sub-rates), it is impossible to do eye open monitor for 480Mbps. but I see some products in the market which use this two chip DS125DF1610 can do this eye open monitor for 518.19MHZ. do you have any idea how to achieve this, via firmware???
thanks in advance!
