TUSB1210 input CLOCK spec
Other Parts Discussed in Thread: TUSB1210, OMAP3515
Dear All
I have a question at CLOCK input terminal of TUSB1210.
By looking at the data sheet, SLLSE09A, I could not find specs of input frequency range, jitter, duty cycle for this device.
Pls advice me.
Rhino
  • Rhino,
    Yes, this information was omitted in the current datasheet.
    The following specification will be included in the next TUSB1210 datasheet release.
    4.1 USB PLL reference clock
    The USB PLL block generates the clocks used to synchronize :
    -          the ULPI interface (60MHz clock)
    -          the USB interface (depending on the USB data rate, 480Mbps, 12Mbps or 1.5Mbps)
    TUSB1210 requires an external reference clock which is used as an input to the 480MHz USB PLL block. Depending on the clock configuration, this reference clock can be provided either at REFCLK pin or at CLOCK pin.
    By default CLOCK pin is configured as an input
    Two clock configurations are possible:
    -          Input clock configuration (see section 4.1.1 below)
    -          Output clock configuration (see section 4.1.2 below)
    4.1.1 ULPI input clock configuration
    In this mode REFCLK must be externally tied to GND.
    CLOCK remains configured as an input.
    When the ULPI interface is used in “input clock configuration”, i.e., the 60MHz ULPI clock is provided to TUSB1210 on CLOCK  pin, then this is used as the reference clock for the 480MHz USB PLL block.
    Table 4‑1 Electrical Characteristics : CLOCK input
    PARAMETER
    TEST CONDITIONS
    MIN
    TYP
    MAX
    UNIT
    CLOCK input Duty Cycle
    40
    60
    FCLOCK CLOCK Nominal Frequency
    60
    MHz
    CLOCK input Rise/Fall Time
    In % of CLOCK period TCLOCK ( = 1/FCLOCK )
    10
    CLOCK input Freq Accuracy
    250
    ppm
    CLOCK input Integrated Jitter
    600
    ps rms
    4.1.2 ULPI output clock configuration
    In this mode a reference clock must be externally provided on REFCLK pin
    When an input clock is detected on REFCLK pin then CLOCK will automatically change to an output, i.e., 60MHz ULPI clock is output by TUSB1210 on CLOCK  pin
    Two reference clock  input frequencies are supported. REFCLK input frequency is communicated to TUSB1210 via a configuration pin, CFG, see FREFCLK in Table 4-2 for frequency correspondence.
    TUSB1210 supports square-wave reference clock input only.
    Table 4‑2 Electrical Characteristics : REFCLK
    PARAMETER
    TEST CONDITIONS
    MIN
    TYP
    MAX
    UNIT
    REFCLK input Duty Cycle
    40
    60
    FREFCLK REFCLK Nominal Frequency
    When CFG pin is tied to GND
    19.2
    MHz
    When CFG pin is tied to VDDIO
    26
    MHz
    REFCLK input Rise/Fall Time
    In % of REFCLK period TREFCLK ( = 1/FREFCLK )
    20
    REFCLK input Freq Accuracy
    250
    ppm
    REFCLK input Integrated Jitter
    600
    ps rms
    Peter
         I would like to ask some help to please send me a link or a copy on a reference schematic for the TUSB1210. We are currently developing a board using OMAP3515 based on Mistral EVM and has already a working prototype except for the USB host xcver port in which we are using SMSC USB3320, it might be on the interoperability problem that is mentioned on the recent errata of OMAP3515. And because of this we would like to replace our ULPI xcver to TUSB1210 but we dont have a guide or a reference schematic to be able to modify our existing schematic. If anyone has a reference design for Tusb1210 please send me a link or a copy of the reference schematic.
    Thanks.
  • Brigols,
    There is already an application diagram available in the TUSB1210 datasheet available on the TI website.
    However if you require more details on differences between TUSB1210 and SMSC USB3320 and how to modify the board I could provide some more details via email.
    Please send me your email address and I will reply directly to you.
    Peter
  • Hi Peter,
           Here is my email ad;
    bambhemichael.brigoli@emerson.com
    Please provide me the details and the needed work on the software side to implement the this chip.
    Thanks and regards,
    Brigols
  • Hi:
    Can you give me more details on differences between TUSB1210 and SMSC USB3320 and how to modify the board? My customer need it urgently.
    And do you have TUSB1210 driver on WinCE? I suggest my customer design AM37x   using TI's TUSB1210 followed by the TUSB2046B, Can you give me some suggestions?
    my email is: rock.li@serialsystem.com
                           315676522@qq.com
    Thanks!
    Peter
  • Hi Peter,
    I would like to know more about the differences between SMSC USB3320 and TUSB1210, would like to introduce TUSB1210 to my customer.
    And if possible, advantages of TUSB1210 over USB3320.
    Thanks.
    My email address: philip.law@marubunarrow-asia.com
  • Did you get an answer for this?
    I'm a different "Peter", but perhaps this could help:
    Not sure if it'll display correctly, but here's a quick XLS I made for a quick in-place replacement of the USB3320 with the TUSB1210:
    Pin
    Number
    SMSC
    USB3220
    USB3220
    Direction
    Board Signal
    TI
    TUSB1210
    TUSB1210
    Direction
    Changes Required for ES2 Debug/Testing
    1 CLKOUT O OPEN REFCLK I tie to ground
    2 NXT O hsusb1_nxt NXT O OK
    3 DATA0 I/O hsusb1_data0 DATA0 I/O OK
    4 DATA1 I/O hsusb1_data1 DATA1 I/O OK
    5 DATA2 I/O hsusb1_data2 DATA2 I/O OK
    6 DATA3 I/O hsusb1_data3 DATA3 I/O OK
    7 DATA4 I/O hsusb1_data4 DATA4 I/O OK
    8 REFSEL0 I/O 1.8V N/C OK - true NC inside TUSB
    9 DATA5 I/O hsusb1_data5 DATA5 I/O OK
    10 DATA6 I/O hsusb1_data6 DATA6 I/O OK
    11 REFSEL1 I/O 1.8V CS I ok - tie high
    12 N/C   N/C VDD15 PO add 2.2uF cap
    13 DATA7 I/O hsusb1_data7 DATA7 I/O OK
    14 REFSEL2 I 1.8V CFG I OK
    15 SPK_L I/O N/C N/C OK - true NC inside TUSB
    16 SPK_R I/O N/C N/C OK - true NC inside TUSB
    17 CPEN O N/C CPEN O OK
    18 DP I/O USB1DP DP I/O OK
    19 DM I/O USB1DN DM I/O OK
    20 VDD33 PO 2.2uF VDD33 PO OK
    21 VBAT PI V_SYSIN VBAT PI OK
    22 VBUS I/O 10K to 5V_USB VBUS I/O Leave as is OR R345 = 0 Ohm
    23 ID I DGND ID I/O OK
    24 RBIAS Analog 8.2K N/C OK - true NC inside TUSB
    25 XO O N/C N/C OK - true NC inside TUSB
    26 REFCLK I hsusb1_clk CLOCK I OK
    27 RESETB I gpio_111 RESETB I OK
    28 VDD18 PI 1.8V VDD18 PI OK
    29 STP I hsusb1_stp STP I OK
    30 VDD18 PI 1.8V VDD18 PI OK
    31 DIR O hsusb1_dir DIR O OK
    32 VDDIO PI 1.8V VDDIO PI OK
    33 pad GND DGND pad GND OK
