Part Number: CLC001
My question relates to the output 75 ohm resistors used in the CLC001 application notes. If the device is being used to drive a 100 ohm twisted pair cable, should the 75 ohm load resistors be replaced with 50 ohm load resistors? Will changing the resistor load adversely affect the CLCL001 output performance?
Thanks for any help you can give,
Rob Curtis
