Part Number: SN65LV1023A
Hi TI,
According to the datasheet for SN65LVD1023, TX clock and RX clock should be spec'd at 50ppm so maximum difference between RX and TX is 100ppm? Or can both RX and TX use 100ppm clock sources?
Also, just wanted to confirm if we have a bit always tied high or always tied low, the receiver won't have a problem aligning to the incoming bit stream. Is it possible that the receiver might get confused for the start of the word?
Thanks in advance!
