Part Number: TS3USB221A
Other Parts Discussed in Thread: TS3USB221, , TS3USB221E
Hello
Thank you for taking the time to read this. We are looking to use your TS3USB221 family of devices. I have a couple questions on them.
1) We are looking to use this in a configuration where on the 1D+/1D- and 2D+/2D- there is a Host connected to each port and the D+/D- is connected to the peripheral device like a KVM switch. Is this a valid configuration using the TS3USB221A chips?
2) Do you have any recommendations using the configuration mentioned in above in 1 on how to hooked up the grounds and VBUS, +5V? Having 2 Hosts creates a problem because you have 2 BUS, +5V, sources. What is your recommendation on this?
3) What is the difference between the TS3USB221A and TS3USB221E versions? Is it just the wider bandwidth of the E than the A?
Thank you for your help
Gary
