Other Parts Discussed in Thread: SN65DSI86
HI All,
I am trying to bring up JDI 4K edp display on qulacomm(msm8996) platform by using SN65DSI86. here is my panel parameters:
H x V(3840 x 2160)
HPW = 32 , VPW = 8 , HBP = 40 , HFP = 8, VBP = 6 , VFP = 48
Panel Support : ASSR .
Number of lane connected to eDP panel from eDP bridge = 4 (0 1 2 3)
Number of DSI channel commected to App processor 2 (CHA and CHB) (DSI laneper channel =4)
I am able to communicate with the Panel via I2C over AUX channel and read DPCD and EDID information correctly but link tanning fails and the error message i get is:
register 0xF8 = 0x12, which indicate this error :( LT_EQ_LPCNT_ERR. This field is set whenever link training fails in the channel equalization phase RCU due to the loop count being greater than five)
I do have a few question about the eDP bridge :
1) Do you have any recommended sample code for eDP panel bringup , i am refereing now from datasheet page 69?
2) Do i need to do Video parameter setting before link tranning ? Does video video parameter setting is required for link trainning?
3) should there be any data comming from DSI input port ( clock or data ) before starting link tranning ?
3) what are the recommend DSI command for configureing eDP register via DSI? I am using 0x29(generic long write) for writting registers , is that correct ?
4) what is the recommend command type for reading the registers via DSI ?
5) Do you have DSI initilization command set for eDP bridge ?
=========================== my code for eDP bridge configutaion via I2C =====
dsi86_write_register( 0x59, 0x93); //DSI lane assignment.For customer board = 0x93
mdelay(7);
dsi86_write_register( 0x0a, 0x06); //27 Mhz ref clock
mdelay(7);
dsi86_write_register( 0x10, 0x80);// Left right pixel / Dual channel DSI receiver/ CHA -4 lanes /CHB - 4 lanes
mdelay(7);
dsi86_write_register( 0x12, 0x6F); // bit clock = 8* byte0 clk ; 1112.72 Mhz / 2 = //DSICH-A clock range //556.18 Mhz by JDI 4K
mdelay(7);
dsi86_write_register( 0x13, 0x6F); //; //DSICH-A clock range //556.18 Mhz by JDI 4K
mdelay(7);
dsi86_write_register( 0x5a, 0x85); //for customer board =0x85
mdelay(7);
/*Link Tranning */
dsi86_write_register( 0x0d, 0x00); // disable PLL en
mdelay(7);
dsi86_write_register( 0x93, 0x30); //24
mdelay(7);
dsi86_write_register( 0x94, 0xE0); //80
mdelay(7);
dsi86_write_register( 0x0d, 0x01); // enable PLL en
mdelay(150);
val =0;
for(i = 0; i < 10; i++){
dsi86_read_register( 0x0A, &val);
if ((val & 0x80)) {
break;
if (i >= 10) {
pr_err("\n >>>>>>>>>>>>>>>>>>>>>>>>>>> SN65DSI86 PLL not ready!\n");
ret = -1;
//ReadDPCDPara(); reading these works correctly
mdelay(7);
//sn65dsi86_read_edid(); this is also correct and matching with datasheet.
mdelay(15);
dsi86_write_register( 0x95, 0x00);
mdelay(7);
dsi86_write_register( 0xF4, 0xFF);
mdelay(7);
dsi86_write_register( 0x64, 0x01);
mdelay(7);
dsi86_write_register( 0x74, 0x00);
mdelay(7);
dsi86_write_register( 0x75, 0x01);
mdelay(7);
dsi86_write_register( 0x76, 0x0a);
mdelay(7);
dsi86_write_register( 0x77, 0x01);
mdelay(7);
dsi86_write_register( 0x78, 0x81);
mdelay(10);
for(i=0;i<5;i++) {
dsi86_write_register( 0x96, 0x0a);
mdelay(110);
val =0;
dsi86_read_register( 0x96, &val);
pr_err("\n >>>>>>>>>>>>>>>>>>>>>> 0x96 = %X\n", val);
val =0;
mdelay(7);
dsi86_read_register( 0xF8, &val);
pr_err(">>>>>>>>>>>> 0xF8 = %X\n", val);
if ((val & 1) == 1) {
pr_err("\n ======== ## Link setup success ##\n");
break;
}else
pr_err("\n ====## Link setup FAILED ##\n");
mdelay(7);
dsi86_write_register(0x3c, 0x18 | 1);
My reg DUmp
[ 26.566435] Dump sn65dsi86 register
[ 26.568928] 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
[ 26.580167] -------------------------------------------------------
[ 26.580173] 00 | 36 38 49 53 44 20 20 20 02 00 86 00 00 01 00 00
[ 26.580176] 10 | 80 00 6f 6f 00 00 00 00 00 00 00 00 00 00 00 00
[ 26.580180] 20 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 26.580183] 30 | 00 00 00 00 00 00 00 00 00 00 00 00 11 00 00 00
[ 26.580186] 40 | 01 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
[ 26.580189] 50 | 00 00 00 00 00 00 20 00 40 93 85 00 10 00 90 00
[ 26.580192] 60 | a0 60 a4 00 00 77 30 30 00 00 00 00 00 00 00 00
[ 26.580196] 70 | 00 00 00 00 00 01 02 01 80 71 17 50 4d 31 33 33
[ 26.580199] 80 | 4d 33 38 35 41 20 20 00 73 1f 7c f0 c1 07 1f 7c
[ 26.580202] 90 | f0 c1 07 b0 e0 0c 00 04 01 00 00 00 00 00 00 00
[ 26.580205] a0 | 01 ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 26.580208] b0 | 04 78 ac ac 08 6c 9c 9c 0c 5c 5c 5c 0c 0c 0c 0c
[ 26.580212] c0 | 3f 3f 0f 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 26.580215] d0 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 26.580218] e0 | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 26.580221] f0 | 00 00 00 00 01 02 00 00 12 00 00 00 00 00 00 00
here is the DPCD /EDID data with registers dump from SN65DSI86
The DPCD 0 byte = 0x12
The DPCD 1 byte = 0x14
The DPCD 2 byte = 0xc4
The DPCD 3 byte = 0x41
The DPCD 4 byte = 0x00
The DPCD 5 byte = 0x00
The DPCD 6 byte = 0x01
The DPCD 7 byte = 0x40
The DPCD 8 byte = 0x02
The DPCD 9 byte = 0x5f
The DPCD 10 byte = 0x00
The DPCD 11 byte = 0x00
The DPCD 12 byte = 0x00
The DPCD 13 byte = 0x0b
The DPCD 14 byte = 0x01
The DPCD 15 byte = 0x00
--- EDID information from panel ---
The EDID 0th byte = 0x00
The EDID 1th byte = 0xff
[ 21.339686]
The EDID 2th byte = 0xff
[ 21.351239]
The EDID 3th byte = 0xff
[ 21.362431]
[ 21.362431] The EDID 4th byte = 0xff
The EDID 5th byte = 0xff
[ 21.398566]
[ 21.398566] The EDID 6th byte = 0xff
The EDID 7th byte = 0x00
[ 21.421521]
[ 21.421521] The EDID 8th byte = 0x28
The EDID 9th byte = 0x89
[ 21.443122]
[ 21.443122] The EDID 10th byte = 0x5a
The EDID 11th byte = 0x38
[ 21.465167]
The EDID 12th byte = 0x00
[ 21.476365]
[ 21.476365] The EDID 13th byte = 0x00
The EDID 14th byte = 0x00
[ 21.498062]
[ 21.498062] The EDID 15th byte = 0x00
[ 21.547728]
[ 21.547728] The EDID 0th byte = 0x00
The EDID 1th byte = 0x1b
[ 21.569216]
[ 21.569216] The EDID 2th byte = 0x01
The EDID 3th byte = 0x04
[ 21.590675]
[ 21.590675] The EDID 4th byte = 0xa5
The EDID 5th byte = 0x1d
[ 21.612099]
[ 21.612099] The EDID 6th byte = 0x11
The EDID 7th byte = 0x78
[ 21.634020]
[ 21.634020] The EDID 8th byte = 0x03
The EDID 9th byte = 0xc9
[ 21.655447]
[ 21.655447] The EDID 10th byte = 0x33
The EDID 11th byte = 0xa4
[ 21.677117]
[ 21.677117] The EDID 12th byte = 0x53
The EDID 13th byte = 0x4d
[ 21.699301]
[ 21.699301] The EDID 14th byte = 0x99
The EDID 15th byte = 0x27
[ 21.713542]
[ 21.713542]
The EDID 0th byte = 0x0e
[ 21.773080]
[ 21.773080] The EDID 1th byte = 0x4e
The EDID 2th byte = 0x52
[ 21.794721]
[ 21.794721] The EDID 3th byte = 0x00
The EDID 4th byte = 0x00
[ 21.816381]
[ 21.816381] The EDID 5th byte = 0x00
The EDID 6th byte = 0x01
[ 21.838423]
[ 21.838423] The EDID 7th byte = 0x01
The EDID 8th byte = 0x01
[ 21.859857]
[ 21.859857] The EDID 9th byte = 0x01
The EDID 10th byte = 0x01
[ 21.881381]
[ 21.881381] The EDID 11th byte = 0x01
The EDID 12th byte = 0x01
[ 21.903127]
[ 21.903127] The EDID 13th byte = 0x01
The EDID 14th byte = 0x01
[ 21.924775]
[ 21.924775] The EDID 15th byte = 0x01
[ 21.974143]
[ 21.974143] The EDID 0th byte = 0x01
The EDID 1th byte = 0x01
[ 21.995530]
[ 21.995530] The EDID 2th byte = 0x01
The EDID 3th byte = 0x01
[ 22.016893]
[ 22.016893] The EDID 4th byte = 0x01
The EDID 5th byte = 0x01
[ 22.038662]
[ 22.038662] The EDID 6th byte = 0x25
The EDID 7th byte = 0xcc
[ 22.059934]
[ 22.059934] The EDID 8th byte = 0x00
The EDID 9th byte = 0x50
[ 22.081187]
[ 22.081187] The EDID 10th byte = 0xf0
The EDID 11th byte = 0x70
[ 22.102584]
[ 22.102584] The EDID 12th byte = 0x3e
[ 22.119121]
[ 22.119121] The EDID 13th byte = 0x80
[ 22.129852]
[ 22.129852] The EDID 14th byte = 0x08
[ 22.134666]
[ 22.134666] The EDID 15th byte = 0x20
[ 22.184869]
[ 22.184869]
[ 22.194352]
[ 22.194352] The EDID 0th byte = 0x08
[ 22.206468]
[ 22.206468] The EDID 1th byte = 0x0c
[ 22.218577]
[ 22.218577] The EDID 2th byte = 0x26
[ 22.231111]
[ 22.231111] The EDID 3th byte = 0xa5
[ 22.243193]
[ 22.243193] The EDID 4th byte = 0x10
[ 22.255277]
[ 22.255277] The EDID 5th byte = 0x00
[ 22.267546]
[ 22.267546] The EDID 6th byte = 0x00
[ 22.279674]
[ 22.279674] The EDID 7th byte = 0x1a
[ 22.291782]
[ 22.291782] The EDID 8th byte = 0x51
[ 22.303837]
[ 22.303837] The EDID 9th byte = 0xa3
[ 22.315895]
[ 22.315895] The EDID 10th byte = 0x00
[ 22.328448]
[ 22.328448] The EDID 11th byte = 0x50
[ 22.340582]
[ 22.340582] The EDID 12th byte = 0xf0
[ 22.349749]
[ 22.349749] The EDID 13th byte = 0x70
[ 22.357211]
[ 22.357211] The EDID 14th byte = 0x3e
[ 22.360295]
[ 22.360295] The EDID 15th byte = 0x80
[ 22.378021]
[ 22.408199]
[ 22.408199] The EDID 0th byte = 0x08
[ 22.413878]
[ 22.413878] The EDID 1th byte = 0x20
[ 22.421920]
[ 22.421920] The EDID 2th byte = 0x08
[ 22.427564]
[ 22.427564] The EDID 3th byte = 0x0c
[ 22.437803]
[ 22.437803] The EDID 4th byte = 0x26
[ 22.448051]
[ 22.448051] The EDID 5th byte = 0xa5
[ 22.456332]
[ 22.456332] The EDID 6th byte = 0x10
[ 22.463701]
[ 22.463701] The EDID 7th byte = 0x00
[ 22.471075]
[ 22.471075] The EDID 8th byte = 0x00
[ 22.478192]
[ 22.478192] The EDID 9th byte = 0x1a
[ 22.482975]
[ 22.482975] The EDID 10th byte = 0x00
[ 22.496429]
[ 22.496429] The EDID 11th byte = 0x00
[ 22.503941]
[ 22.503941] The EDID 12th byte = 0x00
[ 22.509769]
[ 22.509769] The EDID 13th byte = 0xfe
[ 22.515552]
[ 22.515552] The EDID 14th byte = 0x00
[ 22.518742]
[ 22.518742] The EDID 15th byte = 0x4a
[ 22.568910]
[ 22.568910] The EDID 0th byte = 0x44
[ 22.577726]
[ 22.577726] The EDID 1th byte = 0x49
[ 22.577780]
[ 22.577780] The EDID 2th byte = 0x20
[ 22.592511] The EDID 3th byte = 0x20
[ 22.600493]
[ 22.600493] The EDID 4th byte = 0x20
[ 22.601642]
[ 22.601642] The EDID 5th byte = 0x20
[ 22.616382]
[ 22.616382] The EDID 6th byte = 0x20
[ 22.624322]
[ 22.624322] The EDID 7th byte = 0x20
[ 22.634615]
[ 22.634615] The EDID 8th byte = 0x20
[ 22.642104]
[ 22.642104] The EDID 9th byte = 0x20
[ 22.648251]
[ 22.648251] The EDID 10th byte = 0x20
[ 22.653992]
[ 22.653992] The EDID 11th byte = 0x20
[ 22.659678]
[ 22.659678] The EDID 12th byte = 0x00
[ 22.667831]
[ 22.667831] The EDID 13th byte = 0x00
[ 22.673557]
[ 22.673557] The EDID 14th byte = 0x00
[ 22.680497] The EDID 15th byte = 0xfe
[ 22.689614]
[ 22.732112]
[ 22.732112] The EDID 0th byte = 0x00
[ 22.736766]
[ 22.736766] The EDID 1th byte = 0x4c
[ 22.744477]
The EDID 2th byte = 0x50
The EDID 3th byte = 0x4d
[ 22.766075]
[ 22.766075] The EDID 4th byte = 0x31
[ 22.785637]
[ 22.785637] The EDID 5th byte = 0x33
[ 22.798407]
[ 22.798407] The EDID 6th byte = 0x33
[ 22.810557]
[ 22.810557] The EDID 7th byte = 0x4d
[ 22.822628]
[ 22.822628] The EDID 8th byte = 0x33
[ 22.834727]
[ 22.834727] The EDID 9th byte = 0x38
[ 22.846816]
[ 22.846816] The EDID 10th byte = 0x35
[ 22.859379]
[ 22.859379] The EDID 11th byte = 0x41
[ 22.871811]
[ 22.871811] The EDID 12th byte = 0x20
[ 22.884128]
[ 22.884128] The EDID 13th byte = 0x20
[ 22.885383]
[ 22.885383] The EDID 14th byte = 0x00
[ 22.885383]
[ 22.908736]
The EDID 15th byte = 0x73
please give me your feedback ?
Robin Singh
