Part Number: LMH0074
Other Parts Discussed in Thread: LMH0036, , LMH0384
I am designing a video module tasked with multiplexing 4 SD-SDI signals and return a digital indicating the presence of each signal. The application recommendation described in the LMH0036's datasheet fits my need perfectly, and I was planning to use the Carrier Detect CD pin of the LMH0074 for signal detection.
Does the LMH0074's CD output is still updated in BYPASS mode ? The datasheet mention briefly "CD has no function in BYPASS mode." but the block diagram and the Carrier Detect description then make no reference to this.
Also, does the LMH0074 apply some numerical operations to the signal (such as correction using CRC) or is its function purely analog ?
