Part Number: TMDS181
Hi Sir,
We use TMDS181 on HDMI input design and encounter a problem regarding TMDS181 setting. When we use HDMI pattern generator to generate different video format to HDMI receiver though TMDS181, sometimes HDMI receiver stop working when HDMI pattern generator change video format. However, we can fix this issue by changing SIG_EN setting. If we pull up SIG_EN to enable this function, the problem is fixed. However, the datasheet mentioned that “ By disabling the detect circuit, the receiver block is always on, which is needed for certain HDMI CTS test. Could you comment what is side effect in HDMI CTS if we enable SIG_EN function? We are going to produce this product next week. So, we need to make the decision how to set the SIG_EN before 6/25.
