LMH1980: Display observed on VGA monitor getting blanked due to un expected HSYNC Pulses
Part Number: LMH1980
Dear sir,
            I am using LMH1980 as a SYNC separator to separate the HSYNC , VSYNC from green video of VGA(composite SYNC has been inserted in green video of VGA).But un expected HSYNC pulses are observed at output of LMH1980.
Due to this , no video is obsered on Display (i.e display is completely blank).
I have attached the design description and probed scope images with this mail.Kindly check once and help us to solve the problem.
Note : Display configuration -- 1024 X 768 @ Refresh rate 60Hz (Verticle sync polarity : Negative, Horizontal SYNC polarity : Negative)
Tendulkar S
Hardware Design and DevelopmentLMH1980_SYNC_SEP_Improper_HSYNC.pdf
  • The LMH1980 was tested formats using Unigraf VTG-3030 test pattern generator for PC graphics formats using Serrated or (H+V) composite mode.  Here's the link to the test pattern generator datasheet: www.dssrl.com/.../vtg3030.pdf
    Your design generates composite syncs using (H exor V) scheme, so the LMH1980 may not support that.  I recommend you try generating composite sync using Serrated or H+V composite sync mode.
    Alan
  • Thank you for reply.
    But it VTG-3030 ,VTG-3016 it is given that Composite modes
    H+V, H exor V , serrated and my design is same like composite SYNC generated from H exor V.
    Do you have and design scheme or schematics to generate the -- PC graphics formats using Serrated or (H+V) composite mode design.
    Tendulkar S
  • We did not test H exor V with VTG-3030. I don't know how to generate the serrated composite sync. To generate H+V, I think it is just the logical OR-ing of the H and V sync signals.
    Alan
