Part Number: DP83848C
Hi all,
What is the default chip physical address of DP83848.
In my board am getting 1.75volt in PFBOUT pin instead of 1.8 V is it ok or any problem is there .
I cant able to read the physical register of DP83848
Hi all,
Hey Ramasubbu,
The default address for the PHY is 00001. Pin 42 has a weak internal pull-up and 43-46 have weak internal pull-downs so that you can override the default address. I recommend that if you keep the address 00001 that you put discrete 1% or better resistors to ensure proper biasing. Check section 6.4.5 of the DP83848C entitled "PHY Address".
If this answered your question, please hit the green "Verify Answer" button to let me know! If not let me know of any other questions you might have.
Nick
