Part Number: TPS65986
Dear SIr
GRL test fail with TPS65986 as below , may I know to solve this issue or where could I check
Protocol_Ellisys
Hi Kai
Most common issues with failing Ellisys testing is because of a mismatch in VIF information with DUT.
Can you do the following:
Jimmy Hua
Dear Jimmy
OK!! I understand your means
you could see our test result have a "PUT must advertise Rp terminations" fail
May I know where can I config this in "TPS6598x Snapshot 3_05 GUI" ??
TD.4.2.1 Source Connect Sink - Testing Downstream Port |
PASSED |
Applying Sink Terms |
PUT_R must transition to Unattached.SRC |
FAILED |
PUT must advertise Rp |
PASSED |
PUT must enable VBUS within 100 ms to 475 ms (actual was 152 ms) |
PASSED |
PUT must stabilize VBUS before initiating USB PD communications |
PASSED |
PUT must disable VBUS within 670 ms (actual was 14.3 ms) |
TD.4.2.2 Source Connect Sink Accessory - Testing Downstream Port |
FAILED |
Applying Unattached.Accessory Terms |
PUT must advertise Rp terminations |
PASSED |
PUT must enable VBUS within 100 ms to 475 ms (actual was 109 ms) |
TD.4.2.3 Source Connect DRP - Testing Downstream Port |
FAILED |
PASSED |
PUT must enable VBUS within 100 ms to 475 ms (actual was 108 ms) |
PASSED |
PUT must be ready to establish a contract |
TD.4.2.4 Source Connect Try.SRC DRP - Testing Downstream Port |
FAILED |
PASSED |
PUT must enable VBUS within 475 ms (actual was 108 ms) |
PASSED |
Entering Try.SRC |
PUT must disable VBUS within 670 ms (actual was 9.18 ms) |
FAILED |
Entering TryWait.SNK |
PUT must enable VBUS within 475 ms |
PASSED |
TD.4.2.5 Source Connect Try.SNK DRP - Testing Downstream Port |
FAILED |
PASSED |
PASSED |
