Part Number: DP83848Q-Q1
Hi Team,
The following thread describes about compliance test for 100Base-TX.
https://e2e.ti.com/support/interface/ethernet/f/903/p/491013/1773271?tisearch=e2e-quicksearch&keymatch=Pseudo#1773271
In the following each test item, I believe DP83848Q-Q1 generates test pattern by itself and it isn't required to be gererated by external microprocessor.
Is my understanding correct?
ANSI X3.263-1995: Annex J AOI Template, 9.1.6 Rise Time, 9.1.6 Fall Time, 9.1.6 Rise Fall Symmetry, 9.1.9 Transmit Jitter
ANSI X3.263-1995: 9.1.2.2 Differential Output Voltage, 9.1.4 Signal Amplitude Symmetry, 9.1.3 Waveform Overshoot
ANSI X3.263-1995: 9.1.8 Distortion (Duty Cycle)
ANSI X3.263-1995: 9.1.5 Transmitter Return Loss, 9.1.5 Receiver Return Loss
Yaita / Japan disty
