DS110DF410: How to configure the DS110DF410 in bypass mode using the SIGCON Architect
Part Number: DS110DF410
Hello
I need your help to set all the 4 channels of the DS110DF410 in BYPASS mode
Do i do it by setting the output signal seletct to Raw Data?
If not wat is the way to configure the device to work at BYPASS mode?
How can i see it in the registers when i look at the Low Level Page?
Roey Tal
  • You may use the sequence below:
    0xFF       0x0C        //Enable broadcast write to all channel registers
    0x09       0x20       //Override loopthru mux select
    0x1E       0x01       //Output Mux Select CDR Bypass (i..e. raw data mode)
    Rodrigo
