Part Number: SN65DSI84
Our customer use the SN65DSI84, have some questions about "Cold start VCC".
I attach the file write some question.
Could you tell me the answer?
Naoki Aoyama
Naoki Aoyama
Hello Naoki,
EN terminal should be held 1ms after 1.8 Vcc reaches its 90%.
When a GPIO is used to control the EN timing, the external capacitor is no required.
Hello Naoki,
Correct. It is recommended to use a 200nF capacitor. However, the values of the RC circuitry may be adjusted to make sure the low to high transition occurs after the Vcc supply has reached the minimum recommended operating voltage.
