Other Parts Discussed in Thread: DP83867E, DP83867IS, DP83867CS
Hello All,
Does TI produce any parts that are capable of using SGMII? Any help in locating such a part is greatly appreciated.
thanks
Hi Angela,
I'm not clear on what you mean by "capable of using SGMII". We do have processors that can be configured with an SGMII bus, for example, see this E2E thread: https://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/t/300759 .
Is this what you are looking for?
At your service,
~Leonard
Hey Angela,
I'm with Leonard in that your request needs to have some more info so that we can properly assist you in finding a solution. However, I figure that I should mention that if you aren't looking for a processor but for a PHY instead TI does make three that support SGMII communication. They are the DP83867CS, DP83867IS, and DP83867E. They can also be found here in our Ethernet portfolio.
I hope this helps you out and if you provide us with some more info Leonard or I will be able to steer you in the right direction.
Nick
