TCA9555: About setting holding function at power interruption
Part Number: TCA9555
Could you tell me about TCA9555?
Does this device have a function to hold the setting of input port and output port when power interruption for several seconds?
When it restarts after a momentary interruption,
Customer is concerned that data will remain.
Yusuke/Japan Disty
  • Hello Tsukui,
    This part does not have non-volatile memory, therefore, when the voltage falls below Vpor it will loose all its settings. If you know the signature of the fault condition you may be able to put a large enough bulk capacitor to hold the supply up long enough that it will not fall below the Vpor threshold during that event.
    -Francis Houde
