Ethernet PHY and PCB design according to SLVA531A
Other Parts Discussed in Thread: DP83822I
We are designing in a new product that should be using an Ethernet interface. We are trying to choose a PHY device. A simple one with RMII interface.
We are worried about the design of the PCB. We had been told that we should have DISTANCES between the PHY and the magnetics of AT LEAST 1 inch and DISTANCES of 1/2 inch between the magnetics an the RJ45 connector. That seems surprising...
Yet we know that we should have good trace layout for the high-speed signals and differential pairs. We have consulted your SLVA531A documentation and there on page 15 it is written that we should try and make all distances as short as possible,
Would those LONG distance requirements we cited above depend on a certain type of PHY chip or would that be a GENBERAL requirment for Ethernet interfaces?
Thank you in advance for your response.
André Dussault
GEXELEC inc.
418 842 2198
  • Hello Andre,
    The distance requirement is a general guideline that we recommend to customers and not tied to a specific PHY.
    -Regards,
    Aniruddha
  • But are the very short distances recomended in all cases of connection?
    - magnetics to the RJ45 jack?
    - PHY to the magnetics?
    - COU (MAC) to the magnetics?
  • Hello Andre,
    The recommendation was for both PHY-to-Magnetics and Magnetics-to-RJ45. I am not sure what you mean by Mac to Magnetics, did you mean MAC to PHY?
    Leaving 1 inch between PHY and magnetics and 1/2 inch between magnetics and RJ45 should be ok as long as the traces are differential with 100ohm differential impedance. Are you anticipating that PCB space will be a constraint and want to reduce the length?
    -Regards,
    Aniruddha
  • We had had recommendations that the distance between PHY and magnetics should be AT LEAST 1 inch up to 2 inches and that the distance between the magnetics and the RJ45 jack should be at least 1/2 inch.
    That seems to be bizarre, since with correct PCB layout the differential lines could be laid out correctly almost any distance...
    BUT what we are after is keepingthe distances AS SHORT AS POSSIBLE.
    Is there any objection in having those distances as short as possible while keepingthe lines correctly laid out?
    Are there PHY chips that would oblige a design to have those long lengths of traces (or DISTANCES) between the components? We had designed a board with an SMSC LAN8720A and we have a lot of unwanted emissions and someone told us that we should have respected the distances I mentioned above.
    In such a case are those recmmendations for ALL the PHY cips or for SOME? Could you please recommend a PHY chip that could work in the RMII mode and be placed in a tight configuration on the PCB.
    Our concern also lies with ellectromagnetic emissions in order to pass the FCC A-level
    I hope this response is clearer for you, thanking you in advance,
    André Dussault
  • NOTE: the recommendations for the MINIMUM legths and/or distances did not come from TI
    AD
  • Hello Andre,
    Thanks for the additional information. As long as the traces are designed correctly, short distances should not be a problem. Is RMII the only primary requirement for your system? If yes, then I would recommend DP83822I. It is our latest 10/100M Ethernet PHY.
    -Regards,
    Aniruddha
  • Thank you, we will look at tyour recommendation tomorrow morning.
    AD
    Concerning the distance "problem" I want to solve, I found a document by SMSC that I suggest you read because it contains some information that goes agains the "short if possible" approach (the one that I would adhere to and prefer...)
    www.google.ca/url
    Look closely at its Section 2.3 and its section on the distances between the PHY and the magnetics. In that document they also refer to "other PHY vendors", saying "Among PHY vendors, the 25mm rule is considered good practice..."
    Thanking you in advance for your comments and suggestions.
    We have not specifically tested systems with less than 1 inch distance between PHY and magnetics since it would need multiple board designs and multiple EMI test runs. However 1 inch distance between PHY and magnetics should be good for DP83822. Since EMI is a key point for your application, sticking to the 1 inch distance would be better idea. We also recommend not to have any metal beneath the magnetics on any layer.
    -Regards,
    Aniruddha
