SN65DSI84: PLL_UNLOCK always 1
Part Number: SN65DSI84
Hi All,
I am having problem with SN65DSI84,
here is the setup
Test pattern is now working
when test pattern is disabled, only black screen
all registers are configured:
PLL_EN_STAT = 1
PLL_UNLOCK = 0x01
My question is, is the PLL_UNLOCK related or possible cause of problem why there are
no display ?
  • Hello Kermith Galang ,
    The PLL_UNLOCK is the CLK issue. You have to check if this bit is being set back to 1 after it’s cleared. If you continue detecting the PLL_UNLOCK error, the input CLK has a signal integrity issue.
    I can help you to review the device configuration. Please, use the DSI Tuner to configure your panel and export the .dsi file. Besides this file please share the panel datasheet and your schematics.
    Joel
  • HI Joel
    yes, after being cleared, this returns to 1. can you tell me more about the signal integrity issue.
    thanks for your time, I will send the schematic and panel datasheet tomorrow, but for now, is it something related to
    LVDS_CLK_RANGE
    DSI_CLK_DIVIDER
    CHA_DSI_CLK_RANGE
    currently, my dsi clock outputs 420MHz while my LVDS panel accepts around 70Mhz
    which I currently set them to
    010 – 62.5 MHz ≤ LVDS_CLK < 87.5 MHz
    Divide by 6
    and 420< freq <425
  • Hello Kermith,
    Is the DSI clock running HS continuous? Is the LVDS clock running at 70MHz?
  • Hi Jose Jimenez,
    yes the DSI clock is running HS continuous at 420Mhz, also LVDS is running at 70Mhz,
    fortunately, the display is working following the DSI tuner configuration, still I am confuse
    1. dsi output is working if the active line is set to 1920, but the test pattern is always black
    2. when the active line is set to 960, dsi is black, but the test pattern was ok.
  • Hello Kermith,
    Glad to know that it is working.  In pattern mode, the CHA_ACTIVE_LINE_LENGTH filed corresponds to the pixels length that will output to the each LVDS channel individually. In other words, it should be configured with the half of the total active line length.
