Part Number: TPS25740
Just trying to play with a TPS25740 design. Am I reading the datasheet correctly that both DVDD and VAUX are only activated after sink attachment?
Hi Marek,
The DVDD pin can be used as a sink attachment indicator because if a sink is attached the pin will be pulled high. The VAUX pin is used internally for the power management circuitry. VAUX pin will normally draw power from VPWR unless a sink is attached in which case a USB PD contract will be made and VAUX will draw power from VDD.
Jimmy Hua
