Part Number: TPS2065C
Other Parts Discussed in Thread: TPS2553, TPS2069C
Good day Colleagues,
My customer uses the TPS2065CDGNR but claims the Ron resistance is 2 times higher than a datasheet described.
He measured voltage drop with a resistive load (1A@5V) and says values are 0.243V and 0.271V.
Looks like the Ron is around 300mOhm. But the datasheet says in worst case it's 120mOhm.
Power pad soldered to Ground.
Could you comment what can be wrong here and what customer has to check?
Thank you, Mike
