Part Number: DP83822IF
Other Parts Discussed in Thread: TLK110
Hi all
Would you mind if we ask DP83822IF?
Our customer would like to configure EtherCat with transformerless configuration.(AC coupling)
Because, our customer would like to uses backplane instead of Cat5e cable with RJ45 connector.
(The distance between board and board are short.)
We found the same case with TLK110.
http://www.ti.com/lit/an/slla327/slla327.pdf
<Questions>
-Is it possible to cofigure EtherCat with transformerless system?
(Especially, we have to consider backplanes specific - the specification requirements of the return loss for both magnitude and phase.)
-Do you have some EtherCat document with transformerless system?
-Finally, do you have actual experience EtherCat with transformerless using DP83822?
We appreciate your help always.
Kind regards,
Hirotaka Matsumoto
