Part Number: SN65HVD3082E
Other Parts Discussed in Thread: SN65HVD96
I am involved in a new projet with data communication on a 50Vac three phase (without neutral); I have found the SN65HVD3082E that along with SN65HVD96 maybe could do this job; in particular I would like to know:
- If they can be supplied with a 50Vac three-phase power supply without neutral
- If they can communicate on the same three phase multiple end point (>256)
- Whether theycan communicate on the same stand-alone three-phase or whether you need three separate devices to communicate on the three separate lines
- If the AC-coupling is in fact the best way to send data on the 3 phases 50Vac or is better a PowerLine Communication
- If the component can be adapted to operate on the 50Vac three-phase, as kit for the 220Vac is already available.
Best Regards
