Part Number: SN65DP141
does the chip support edp to dp redriver?
or only support edp to edp, dp to dp.
#Hui
#Hui
Hi Fracisco,
In DP1.3 spec, table D-3: DP main-link TX silicon parameters, say VTX-DIFFp-p-Level0 is w/ 0.34v(min), 0.4v(nom),0.46v(max)
in edp1.4a spec, table 4-1:recommended tp1 differential signal voltages, say Differential Peak-to-Peak Output Voltage 0 is w/ nominal Vdiffp-p 200mv
In a nutshell, the input lane voltage(edp) is different w/ the required output lane signal(DP).
How to address the different AC spec of edp to DP w/ the DP141? use GAIN?
What special edp support of DP141 can offer?
Best regards
#Hui
