Part Number: DP83867E
Hi
I have XCKU040 Custom Board with DP83867 similar to KCU116,VCU116 connected sgmii 6wire. (sync mode)
i connect 1g pcs/pma ip core to tri mode ethernet ip core. but in AN process i get /bc 4a 01 98 bc a2 01 98/ and sync failed.
sgmii is over LVDS,
when i connect ethernet cable to board, i get /bc 4a 01 98 bc a2 01 98/ and when i remove cable i get /bc 4a 01 00 bc a2 01 00/
the RX_CTRL is strapped to mode 3.
i think correct sequence is /bc b5 xx xx bc 42 xx xx/. why this sequence is wrong?
