Part Number: HD3SS215
Hi ,
We designed a board with 4 DVI switches HD3SS215 for HDMI port switching.The issue is we are failing the HDMI TDR testing.The differential lines are designed for 100 Ohm impedance.The Bare PCB test reports for impedance is within 10% margin.We are using ESD diodes and common mode choke between DVI and HDMI connector.What could be the reason for this failure.
Thanks in advance!
James Jose
