Hello Team,
DS90UB954-Q1 datasheet suggested beads (1500k-ohm+1500k-ohm) at PoC are different than 954 EVM (47-ohm+330-ohm) suggested.
May I know which one is suggested?
Thank you.
Ting
Hello Team,
Thank you.
Ting
Ting,
The FB is used to block the high speed forward signals at ~2Gbps, it is better if impedance is higher. so 1500ohms in d/s is better than the design in EVM's board. You can use d/s's suggestion for your customer, thanks.
best regards,
Steven
