Part Number: SN65DSI83
Other Parts Discussed in Thread: SN65LVDS822
Hi there,
Would sn65dsi83 be the right solution for MIPI DSI to YUV (RGB) Bridge?
The Spec of the LCD panel is attached.
Roy Hsu
Hi there,
Roy Hsu
Hi there,
To give you more information about the application, the DSP used by the customer supports MIPI; however, the display format of the LCD is RGB888.
Therefore, my customer would like to know if SN65DSI83 is the right part for them.
Thank you!
Roy Hsu
Hi Joel,
I asked my customer for the specs and will get back to you when I receive their response.
Thank you.
Roy Hsu
Hello Roy,
Thanks. If you prefer you can send me the complete panel spec via email.
Hi Joel,
Customer provided the following information: 720x480 x RGB x 30 fps = 31.1M
Is that what you need?
If not, could you tell me what are the key parameters that I should look at to determine if this is the right part?
Is there any guideline on choosing this kind of device?
Thank you!
Roy Hsu
Hi Joel,
I found that you suggested a dual-chip solution, SN65DSI83 and the SN65LVDS82, for the MIPI-DSI to RGB parallel interface bridge.
My customer's application is also MIPI to RGB888. Do you think this is suitable for this request also?
Thank you!
Roy Hsu
