Other Parts Discussed in Thread: TUSB2077A
Please refer to page 4 in the datasheet of the TUSB2077A 7-port USB Hub controller. (
Thanks a lot.
Binh
Thanks a lot.
Binh
If the TUSB2077A implements power management then the PORTPWR pin(s) will be high whenever port power is enabled by the USB host. The PORTPWR is not dependent on having a downstream device installed. Typically a USB host will turn on the port power once the hub is enumerated.
