DS90UB913A-Q1: How to Reduce Radiated Emission
Part Number: DS90UB913A-Q1
Hello Team,
May I know if there are methods to reduce SER radiated emission?
1. I think reduce SER output swing can help but do not know how to adjust SER output swing.
If there is register to adjust SER output swing, please let me know.
2. And for hardware adjustment, could I add smaller value caps at SER output DOUT+ or adding trace impedance to make output smoother? As long as the attenuation is less than DES EQ compensation capability, implement above method should be okay?
Thank you.
Ting
  • Ting,
    UB913a output swing can not be adjusted.
    For your EMI issue, please check the detailed test issue, such as freq. point. in general, shielding cable should be well for the EMI test. After you identified the EMI test issue, you can check the oscillator, cable, connector, shielding etc. to improve the system level EMI/EMC design.
    best regards,
    Steven
