Part Number: TUSB4041I
Hi, I have managed to test the High-Speed Signal Quality (HS-SQ) for the hub upstream port by enabling the TEST_PACKET using USBHSET version 1.3.2.0 for EHCI software collected from usb.org site. I have not managed to start the TEST_PACKAGE for the hub downstream ports. I assume the TUSB4041i device support test pattern to be enabled on the downstream ports 1-4. Can you please explain how to enable the test pattern for the downstream ports using the USBHSET software.
/Regards Mikael Grönhage
