Other Parts Discussed in Thread: TS12A4515
Hi Team,
Does TI have analog switch that can be used for CAN Termination Switch?
I would like to suggest to my customer if there is.
Yaita / Japan disty
Yaita-san,
There are many passive FET switches that can be used in CAN applications but we need to understand the parameters of your CAN signal to make the appropriate selection.
Would you please provide us with your desired configuration? 1:1, 2:1, 4:1, etc
How many integrated systems would you like in your system?
What is the voltage level of your CAN signal?
What is the bandwidth or datarate of your CAN signal signal.
I aslo found this e2e thread searching for CAN switch in the switches and multiplexers e2e forum.
Thank you,
Adam
Hi Adam-san,
Thank you for your support.
My customer is looking for analog switch that can be used for CAN Termination (120Ω termination) as the following.
The voltage level of CAN signal is -2V~7V.
In addition, he also wants automotive grade(-Q1) device.
Is there any analog switch that meets requirements above?
Yaita / Japan disty
