Part Number: DP83867IS
I'm currently trying to test all pairs/channels of a DP83867IS with a 1000Base-T connection with the LeCroy QualiPHY QPHY-ENET.
I tried the commands given in SNLA239A, page 12-13. This works fine for channel 1, but I'm having trouble to get the PHY test mode waveforms on channels 2 - 4.
When powering up or resetting the PHY, the link pulses can be seen on Channel 2. Channel 3 and 4 does not show any signal.
When specifying a test mode (e.g. setting Reg 0x0009 = 0x3B00 //Test Mode 1), the link pulses on channel 2 stops.
Setting the output to all channels with "Reg 0x0025 = 0x0480 //output test mode to all channels" does not change anything.
Is there any command missing to send the test waveforms on all 4 ethernet pairs or is this not possible?
Christian
