Part Number: TCA9801
Let me talk about the using TCA9801.
I got two questions from customers.
① B-side has internal current source. Therefore, a pull-up resistor is not required.
Is there a problem when the pull-up resistor is installed outside the TCA9801?
Customers want to know the risk of the case of installing the pull-up resistor added.
② Is it OK to use either A-side or B-side as Master?
Could you give me your advice?
Yusuke/Japan Disty
