Part Number: SN75176B
Other Parts Discussed in Thread: THVD1510, SN65HVD1786, SN65LBC184
We are using SN75176B for MODBUS rs485 communication with Isolated DC supply. Earlier we used Zener diodes for protection at A and B, in some cases these zener diodes getting shorted or opened due to this entire network getting stopped communication with Master.
Now we removed all zener diodes and replaced SM712, here we observed that in one of device in a network B and Ground pins got short and the same device communicating with Master and working fine and remaining all are failed to communicate with master and remains in the same position (Hanged). After removing the failed device from loop then the remaining all are working fine.
Can you please suggest any solution for the failure.
