Part Number: ISO5852S-Q1
On the ISO5852S-Q1 when a DESAT fault occurs, the driver enables a soft turn-off. How does the soft turn off work? What is the Soft turn-off resistance (by the external Roff and internal FET) and can it be change?
Hi David,
In case of DESAT protection, a current source is generated inside the driver IC to discharge the gate capacitance of the power transistor. The impedance of the current source is around 60ohm (typical value).
With Regards,
Xiong
