Part Number: TCAN1042HV
Hi there,
Would you be able to review the attached schematic (the CAN Bus part) for me?
Thank you!
Roy Hsu
Hi there,
Thank you!
Roy Hsu
Roy,
This schematic is setup correctly. The only part I would check is the FET on the bus, making sure it doesn't add too much capacitance or propagation delay. Looking at the datasheet, it will add 50pF, which is fine, just something to keep in mind.
One more thing, are the TXD and RXD lines connected to an MCU with internal pull ups?
Hi Eric,
Yes, they are connected to pull-ups.
Another question I have is that, is there any suggested impedance value for the CANH / CANL traces?
Thank you!
Roy Hsu
Roy,
They should be the same length, and impedance matched 120Ω differential, 60Ω single-ended. That is, with respect to GND, 60Ω should be seen on CANH and 60Ω should be seen on CANL, but differential between CANH and CANL should be 120Ω. The traces should be run parallel to each other with the same spacing in between the traces throughout, and routing should be planned in a way that will avoid crosstalk from other signals.
