Part Number: TUSB212
Other Parts Discussed in Thread: TUSB1002
Customer is considering to use TUSB212 in cascade connection to cover long cable.
I got two questions from customer.
1.Can TUSB212 be used in series?
And Is it possible to connect more than 3 devices in series between host and device?
Do you have a proven design used in cascaded connection?
2.Is there a measure of described the EQ gain (+xx dB at xx Hz) that TUSB212 can compensate?
For example, In the case of TUSB1002, the following contents are described in datasheet.
Could you give me your advice?
Yusuke/Japan Disty
