ISO7240 Isolator lock up
Other Parts Discussed in Thread: ISO7240C, ISO7240M
I used ISO7240 in my design to isolate external GPIO. Several of external GPIO are regular rocket switch, there is no debouncer circuit  between isolator and between the GPIO.
The rocket switch operated manually, in some occasions i can catch strange behavior of isolator like as output lockup. On switching to logic high in the input, the output remains on logic low. I believe this happened due to glitches on input. I tried low pass filter and found that catching lock up became much harder then before.
I would like to know if my assumption regarding lockup is correct and if this is normal IC behavior?
Yoni
