DP83848C: DP83848C for Fiber optic transmission
Part Number: DP83848C
Other Parts Discussed in Thread: DP83822IF
I'm using DP83848C Ethernet Phy controller for my copper Ethernet communication with out any problem. I made a provision to fit Avago AFBR-5803Z Ethernet fiber model in my PCB. But unfortunately my communication is not working with the fiber optic module. I've attached my circuit diagram here.
1. Do we need to change anything in our circuit diagram to work with both (Either one at a time) Fiber and Copper network?
2. Is it possible to use DP83848C for fiber communication?
3. If not, do you have any Phy from TI which is pin compatible with DP83848C?
Udhay
DP83848C Circuit.pdf
