Part Number: DS90UH947-Q1
I would like you to confirm about below.
* Which case should we use "28BIT serializer mode" ?
If you have any usecase about this mode, please let me know.
Mahcida
Mahcida
Hello Darryl-san,
Thank you for your reply.
>Sorry for the delay. I checked with Design and this function may not work.
>If you need, I can check on the bench.
According to our and customer's confirmation, when we set both this setting and add 0x03[1] (DE RGB GATE), we could not observe data output from OLDI.
If one of above two bit change to "0", we can observe data output from OLDI. So, it seems this function works.
Q1. Could you please perform double-check whether this function actually does not work ?
Q2. If this function does not work correctly, could you please remove this bitfield ?
Hi Machida-san,
I tried on 947EVM to 948EVM and 28B does not work. I configured single and dual link and throughput does not change. I will enter into our datasheet updates to remove this description.
