Part Number: DS90UB954-Q1EVM
Other Parts Discussed in Thread: ALP
I am trying to get a working demo using the 953/954EVMs. After changing them to the correct profiles the 953's I2C device id is x30, which according to the 953 userguide is correct. However, the 954's i2c device id is x60. In the 953 userguide it says the expected id is x7A, but the 954 userguide says it is x60. Which value should the 954's device id be?
Also, assuming x60 is correct, when I run the script to initialize the sensor neither the horizonal nor the vertical parameter changes from 0. I ran the script in the 954's scripting section in ALP. Thank you!
Adam Daluga
