DS90UB913A-Q1: request schematic review
Part Number: DS90UB913A-Q1
if you have any detail documents about ds90ub913a-q1 configuration, please share for us.
thanks,
TS
    Please do not post customer schematics on E2E since this is a public forum. You can contact your TI support person offline for schematic reviews - in this case this has been assigned to an engineer who can work with you offline to review and provide any feedback.
    For additional 913A documents refer to this TI link: www.ti.com/.../technicaldocuments
    The datasheet provides a typical connection diagram and the layout guidelines. You can also refer to the 913A EVM user guide under this link for the EVM schematics/layout to use as a reference.
  • TS,
    what is the configuration that you need?
    UB913a is one high speed serializer device, which converts parallel data (including video data, control data such as I2C etc.) to serial output. For UB913a setting, it is simple, you can select the REFCLK source via hardware pin setting (mode_sel) or register setting. please refer to d/s. also, 913a can support 10bits or 12bits HF mode, you need configure it from the paired de-serializer's mode_sel pins, such as UB914a/934/964 etc.
    so in most cases, UB913a can run well automatically without any register settings.
    please let's clarify more if you have any confusions.
