DS280DF810: request schematic review
Part Number: DS280DF810
Below attached schematic is from one of our most important customer, so could you check whether there's any potential problem or not?
M3000_RETIMER.pdf
thanks,
TS
  • I will review the schematic and provide my inputs by this Friday USA Pacific Time.
    Cordially,
    Rodrigo Natal
    HSSC Applications Engineer
  • Hi, I reviewed the schematic. My inputs below.
    Checked and ok
    • VDD decoupling
    • Oscillator for CAL_CLK_IN
    • High-speed inputs and outputs -> no external AC coupling caps as the retimer implements integrated AC coupling caps
    • ADDR pin strap options
    • READ_EN_N floating for SMBus Slave Mode
    • ALL_DONE_N floating
    • INT_N to system input
    • TEST pins floating
    Comments
    • EN_SMB is 2.5V LVCMOS input pin. Recommend to use 1kOhm pull-up to 2.5V for normal operation in SMBus Slave Mode
    • Assuming that retimer SDA and SCL are pulled to 3.3V somewhere on the system boards
    Cordially,
    Rodrigo Natal
