DP83620: Reference part number for the TD matching capacitor
Part Number: DP83620
Considering the recommended schematic for the Fibre Optic Transceiver connection (figure 9-2 page 63 of the datasheet), which is the recommend part number of the 0.1uF capacitors?
Which is the maximum frequency of FXTDP ad FXTMD signals?
Thank you,
Alessandro
  • Hi Alessandro,
    We do not have recommended part numbers for 0.1uF capacitors. The DP83620 evm has used 0.1uF ceramic capacitors, so you can use similar capacitors from any vendor. The FX signals are as per the 100Base-FX standards and will be 125MHz.
    -Regards,
    Aniruddha
