P2P solution with AX8712
Other Parts Discussed in Thread: TPS2595, TPS25200, TPS25921A
Hi Team,
Do we have any P2P solution with AX8712? Customer would like to replace this one with TI solution. Thanks.
http://www.axelite.com.tw/Doc/BinaryData.aspx?id=d1e85edb-ac58-4829-92e1-6e6f7cd12aba
NIc
  • Hi Nic,
    Unfortunately, we don't have P2P solution for AX8712. But we have better performance device in small form factor. TPS2595 has 50% less Ron in 2mm*2mm size with +/- 7.5 current limit accuracy. Can you show TPS2595 to the customer and check their feedback.
    Can you please share the application use case and the end equipment?
    Rakesh
  • Thanks Rakesh for the quick response. The end equipment will be notebook.
    I checked that TPS2595 max current is 4A. However AX8712 is 1.5A. Do we have lower current version? I am assuming that the cost will be lower as well.
    Nic
  • Hi Nic,
    TPS25200 (up to 2.5A) and TPS25921A (up to 1.6A) are the low current options. Please email us the price expectations for this requirement to take this discussion further.
    Rakesh
